Very basic grid question????
Yes, most valve grids have two sides, corresponding to two support rods. In most cases the external grid pin is attached to just one of these - this is sufficient as the whole grid is metal anyway. Some high frequency valves, intended for grounded grid operation at VHF/UHF, have two or more grid connections externally in order to reduce the inductance of the grid connection - this improves gain and stability.
When such a valve is used for audio it is usually necessary to add a grid stopper in order to deliberately reduce its RF gain and so avoid instability. Many people use both grid pins for audio and then a grid stopper is needed for each pin. I don't know why they do this, as I think a single connection and single stopper is sufficient.
Connecting pin2 to 8 externally is, at audio frequencies, merely paralleling an existing internal connection so does no harm or good. You can use either pin for the grid. 220 ohms seems a bit too small for a stopper - I would use at least 1K. There was some nonsense on here a few months ago about small value stoppers being better, and that seems to have sent people off down the wrong path. If you use both pins then you need a stopper on both pins.
I wonder whether your confusion is caused by the fact that the standard way of drawing a valve grid makes it look like a set of separate bits of metal when in fact it is all connected together. If you use a meter you will find a dead short between pins 2 and 8.
