Verbose some questions???????
You know you can email me if you want 😉 . Anywho, seems like the money is pouring in now with my projection panel sales, so I will be able to get all the "stuff" in a few days. I emailed the seller about the digi-cam to try and buy one outside of ebay. As for lighting, im using 250 watt metal halide hqi. I (negative design actually) "may" have found a ballast that will work with hqi for $17 euros... No joke. Anywho, I'll be starting by the end of the month.
Did you ever figure out the wierd way in which the nview panels vga inputs work, Im thinking I may Buy a voltmeter to get the pinouts for the ends, I assume If Its used it will beep( the voltmeters make a sound right, or do they just show a small current) and if its not used It wont do anything.
