Vented alignments
Some very useful reflex alignments are the QB5 II filter assisted variety, described here
http://sound.westhost.com/qb5align.htm
these optimise the coupling between the driver and the Helmholtz resonator and can greatly increase the excursion limited power handling of a given driver.
When suitably scaled these can be used in conjunction with the high pass "small front" filter found in 5.1 systems, allowing a smaller satellite to fill a larger room with minimum distortion.
rcw.
rcw.
Whilst it does what it says on the tin, it is still a poor acoustic choice
for the proper bass end of a system, good for satellites with higher
order acoustic crossover slopes to the subwoofer, if that is wanted.
🙂/sreten.
Sorry for being lame in a respone...
I want to say a "Big Thanks!" to :
richie00boy
Svante
Ron E
oshifis
sreten
PB2
audiokinesis
IngOehman
rcw
ramkumarr
for your Help in understanding vented alignments. I am
honored at your responses and have cut and pasted each.
Kudo's to each for your contributions to little such as I.
PS. Thanks
Again... I feel honored to be in the presence of Giants.
Kindest Regards,
Mike Williams
