veneer on back of bb plywood
Veneer sites suggest it is essential to veneer or back the reverse side of any panel one veneers. for a speaker, this would imply someing on the inside face of the speaker panels, in my case bb plywood. the rational is to prevent differential moisture absorption. but i would be really worried about this creating voids or even loose edges to buzz. any experience wih whether this should be necesary?
True, I've also wondered whether a 0.6mm layer of veneer would have much effect on 18mm plywood. I have done veneered MDF cabinets, and only done one side, as in the UK veneer is expensive, I wanted to use quilted maple for my current project, it would have cost me over £400!!! Used pre-veneered (American Black Walnut) MDF instead.
The only purpose for 'balance veneer' is to prevent unbraced flat panels curling from differential tension arising from moisture movement. A 'balancing veneer' doesn't need to be the exact same quality as the finish at all - it can be anything with similar properties. Hence (at the low end!) you find melamine worktops with paper on the back of a chipboard core...
With good quality ply and a braced construction there's no need as already stated.
