Hello,
I have a Velodyne ULD-15 that recently started with a repeated ticking sound through the driver. Other than the ticking, it still works as it should. As I have three of these units, I tried swapping out the cabinet and observed the same issue. I then tried the original cabinet with a different amp and it works without the ticking. I'm guessing I have a capacitor that is discharging and as such creating the ticking.
A visual inspection of the boards show nothing out of the ordinary. Is it worth grabbing an ESR meter and going through all the caps? Or is it possible that there is something else causing this? Suggestions?
Thanks a bunch,
Mike
Thanks a bunch,
Mike
