I find these are superb for making up test rigs. But I basically never order from PE, and yet order from Mouser a lot.
Maybe I'm inept at searching for parts, but I can't for the life of me find the same(ish) thing on Mouser. I order from Digikey some, but not as often.
I'm hoping anyone that has gone through the ordeal to locate something that is good for test rig, but good enough to keep as well.
Those boards seem to have a standard hole to hole spacing of 2.5mm or .01"
They are stated to be compatible with DIN41617 connectors.
https://www.vellemanusa.com/products/view/?id=350320
https://www.google.com/search?q=DIN...1pol-gerade-printstifte-din41617.html;720;480
I don't see anything special about them as they have the same hole dimension's of a standard protoboard.
Same as any of the 4"x3" or any size types that you can find at a Radio Shack or any other major electronics supply house.
Here is Mouser's list for that size that includes many different types of pad patterns,
http://www.mouser.com/Tools-Supplie...zvfapZ1yzr94yZ1yzxiuiZ1yzxiwdZ1z0jliuZ1yzu1t0
This one is of similar size with the same standard checker board pad pattern for $6.82 only the holes are slightly smaller at .037" dia. instead of .041 dia,
http://www.mouser.com/ProductDetail...=sGAEpiMZZMtgbBHFKsFQgo04jOHntgNPlAQqhq0Bfzs=
http://www.busboard.us/pdfs/BPS-MAR-(PAD2)-001.pdf
Or this one for $5.66 as it will fit I.C.'s as well
http://www.mouser.com/ProductDetail...GAEpiMZZMtgbBHFKsFQgo04jOHntgNP%2bjkQTahR8/M=
http://www.busboard.us/pdfs/BPS-MAR-(PR2H2)-001.pdf
FWIW
jer 🙂
FWIW
jer 🙂
