Vas is inversely related to the stiffness of the woofer suspension, and Vb is inversely related to the stiffness of the enclosure. The ratio of Vas and Vb (known as alpha=Vas/Vb) is called the compliance ratio. It doesn't really matter what the ratio is, as long as you understand how the ratio influences response shape to get your desired result.
How about an acoustic suspension woofer? Supposedly for such a woofer, alpha must be greater than or equal to 3. Also I was wondering if it is possible to identify an acoustic suspension woofer by its T/S parameters.
Vilchur's original woofer absolutely needed alpha > 3. I guess acoustic suspension isn't so prominent anymore.
Bet I stumped you all with these questions
Well, if you want a Qtc of 0.7 and use a woofer with a Qts of less than half that, you have designed an "acoustic suspension" system
I was referring to an acoustic suspension woofer driver, not the system. An acoustic suspension woofer has a Vas much greater than that of a non-acoustic suspension driver of the same diameter. In other words, in a sealed system, the acoustic suspension woofer is acoustically suspended to a greater degree or the restoring force comes mostly from the air cushion rather than from the woofer's spider and surround.
Like I said, a Vilchurian devilr woofer in a sealed system with alpha equal to one couldn't handle any power at all because of an inadequate restoring force.
It seems like there aren't any commercial Vilchurian woofers around these days, nevertheless for example David Weems in one of his books that I have seems to take the view that alpha = 1 (in a sealed system) should be reserved for relatively small drivers such as 4 inch dia. or less.
The idea I believe is that compliance of most large woofers (> 4 inch dia.) is going to be too great if alpha <1 in a closed box and thus severely limit power handling. The restoring force is too weak relative to motor strength.
cT
It seems like there aren't any commercial Vilchurian woofers around these days........
True, you need a really low Fs + really high Vas to get down low in a compact box. Altec had a number of drivers with Vas as high as 1 k L, but to get down to 32 Hz requires a ~12 Hz Fs.
GM
GM
The insight of Neville Thiele was transforming both electroacoustic (driver) and enclosure characteristics into electrical analogs, and using standard filter-design techniques to synthesize the required response shape. Since he was working on Australia's color-television project at the time, he was familiar with the frequency response, phase response, and group-delay characteristics of commonly used filters.
(NTSC, PAL, and SECAM analog television require filters with well-defined characteristics in transmission and reception, or color will appear obviously distorted. NTSC, in particular, requires very accurate filters with smooth group delay throughout the entire transmission chain, from camera to receiver. It should be remembered at the time of publication of Thiele's first papers in Australia, the European PAL system was in the early stages of lab development, and still six years from public introduction. NTSC was in regular use in the USA, but the high cost of receivers limited viewership to less than 5% of the public.)
It's unfortunate that Neville's work took more than 10 years to appear in the American Journal of the Audio Engineering Society, but it finally appeared alongside a condensed version of Richard Small's doctoral thesis. This is how Thiele/Small theory made its belated appearance to the world of audio design in the early Seventies. I still have the original issues of the AES Journal sitting in my library (back when I was a member of the AES).
Once you convert everything to an electrical analog, it's obvious that driver compliance (normalized to Vas) and box volume are in series with each other (in a closed box). So it doesn't matter where the restoring force comes from; either the driver suspension (if a true infinite baffle is used, like an opening to the outdoors), or mostly from the air in the box, the original AR-1W approach, or any combination in-between. It's simply a 2nd-order highpass filter, with (total) compliance as one of the reactances, and the moving mass of the cone as the other reactance.
In practical systems, the majority of damping is provided by the amplifier, not the mechanical resistances of the suspension. Although vacuum-tube amplifiers of the Fifties had a higher source impedance (or lower damping factor) than modern transistor amplifiers, nearly all commercial designs employed about 15 to 20 dB of feedback, and had source impedances in the 0.2 to 0.5 ohm range, which makes them near-voltage sources for purposes of T/S calculations.
The greater insight of Thiele and Small was analyzing a vented-box as a 4th-order highpass filter, with driver compliance and moving mass forming two of the reactances, and enclosure volume and equivalent mass of the vent forming the other two reactances. In the Fifties, you could build a few boxes, measure them, and arrive at a reasonable 2nd-order filter, but the chances of getting a 4th-order filter correct by cut-and-try are very slim. That's the reason that Fifties' vented alignments sound the way they do; there was no guide from filter theory, no agreement on how to measure a box at low frequency, and no set of standardized driver parameters.
In other disciplines of engineering, electrical analogs between moving mass (inductance), spring compliance (capacitance), and friction (resistance) arrived earlier. It just took a bit longer for it to arrive in the sphere of loudspeaker design.
The papers of the 1950's are not easy to read compared to the clarity of Neville Thiele's first paper, and the greater clarity of Richard Small's papers ten year later. The lack of standardized measurement protocols didn't help. Harry F Olson and the Western Electric team were using electroacoustic analogs in the Thirties, but did not come up with a generalized theory of enclosure and driver design with the scope and power of T/S theory.
GM
I have to admit to not having the faintest idea of what a Vilchurian woofer is. So GM or anyone else here who knows, would you please explain to me what a Vilchurian woofer is? I'd really appreciate it...
I'm listening to: From Me To You by Tom Coster
Thetubeguy1954 (Tom Scata)
"Problems of Bass Reproduction in Loudspeakers" by Edgar M. Villchur, JAES July 1957. In that article, Villchur describes I suppose the first acoustic suspension woofer. In a whimsical mood, I decided to call acoustic suspension woofers Villchurian woofers.
The Villchurian woofer typically has a very low Fs as a result of having an exceedingly compliant spider. That also means that the air cushion overwhelmingly must provide the restoring force.
cT
P.S. Thanks to Lynn Olson for his post about the electrical analogy. I was wondering about being able to quantify power handling as a function of compliance.
cT
Hi cT!
Thanks for your explanation. I know what an acoustic suspension woofer is and how it works. Knowing an acoustic suspension woofer = a Villchurian woofer explains exactly what I needed to know.
I'm listening to: Sprawl by Sprawl
Yes, the correct spelling is double l, Villchur. My preference would be that I don't misspell names.
Thinking about power handling and how it relates to compliance, and knowing that
Par(cb) = Kp*(f3)^4*(Vd)^2
and Kp is a function of Qtc, I realized that Qtc, which is partly a function of system compliance, is the important characteristic as far as power handling is concerned. Compliance is one of three factors determining Qtc.
So alpha equal to or less than one for a closed-box system and driver of large diameter (say 8 inches or greater) might not necessarily mean poor power handling.
If anyone not knowing the above equation for Par wants an explanation of the terms of the equation, I will do that. -Not sure that there is any interest.
cT
cT
Would a speaker with these Specifications work in an 18 cubic foot cabinet {Ported}?
Best cabinet for that would (probably) be:
3 cubic feet tuned to 48 Hz or
4 cubic feet tuned to 45
So if you have 6 of them, you can use your 18 cubic foot cabinet
Okay, okay.....alright, you win. (sigh) Rereading Small, he says that for Qtc equal to or less than 1.1, there is no change in (displacement limited) power handling. Even for Qtc >1.1 to me it doesn't seem that much of a change occurs. Considering of course, um, program material in other words music reproduction.
Except for the Villchurian woofer, your advice is good coin.
cT
- Vas Question
