Add:
6Н7С - 31 pcs. for $1,5/pcs.,
6Н8С - 19 pcs. for $1,5/pcs.,,
6С19П(В) - 140 pcs. for $1,5/pcs.,
I'll take the 6H8C, sent you PM.
6N8S (1578)
I sale is one SUPER RARE MELZ NOS 1578/6N8S/6SN7GT/ECC32 Holes T-Plates tubes Metal Base. Made by MELZ (Moscow electro-lamp plant). The tubes are NEW and well balanced. I have 71 pcs for $60/pcs.
Add 6S33S-V - 4 pcs. for $30/pcs.
6S33S-V - a powerful indirectly heated triode, intended to act as a regulating tube in electronic voltage regulators fixed and mobile devices for special purposes. Full analog - 6S18S vacuum tube. It has two filaments, thereby can work in one and two of the cathode, respectively, with a maximum thermal capacity of the anode 30 or 60 watts. Permissible to use this lamp in audio amplifiers. In the single-ended output stage is enabled with one lamp 6S33S can achieve output power greater than 12W. In the push-pull circuit pair of lamps easily produces more than 100 watts in class AB. Very cool sounds in single-ended scheme.
NOS.
NOS.
I have now:
E88CC Tesla - 46 pcs. for $50/pcs,
1J17B - 5000 pcs. for $1/pcs,
1J18B - 11000 pcs. for $1/pcs,
1J24B - 23000 pcs. for $3/pcs,
1J29BV - 2000 pcs. for $1/pcs,
1J37B - 1000 pcs. for $3/pcs,
1P24BV - 2000 pcs. for $1.5/pcs,
2J27L - 7000 pcs. for $1.5/pcs,
2P1P - 900 pcs. for $4/pcs,
4P1L - 200 pcs. for $2.5/pcs,
5C4S - 500 pcs. for $2.5/pcs,
6E1P - 30 pcs. for $7/pcs,
6E3P - 80 pcs. for $6/pcs,
6E5S - 300 pcs. for $15/pcs,
6J1B - 200 pcs. for $0.5/pcs,
6J1P-EV - 1000 pcs. for $1.5/pcs,
6J2P - 1500 pcs. for $1/pcs,
6J5BV - 3000 pcs. for $1/pcs,
6J9PE - 3000 pcs. for $1.5/pcs,
6J43PE - 500 pcs. for $1.5/pcs,
6J45BV - 400 pcs. for $1/pcs,
6K4PEV - 6000 pcs. for $1/pcs,
6N1PVI - 9000 pcs. for $2/pcs,
6N2PER - 2000 pcs. for $2.5/pcs,
6N3PEV - 13000 pcs. for $2/pcs,
6N6PEV - 200 pcs. for $6/pcs,
6N6PI - 400 pcs. for $2/pcs,
6N8S - 300 pcs. for $2/pcs,
6N9S - 300 pcs. for $2/pcs,
6N13S - 50 pcs. for $5/pcs,
6N16BV - 1500 pcs. for $1.5/pcs,
6N17BV - 900 pcs. for $1.5/pcs,
6P1PEV - 1000 pcs. for $1.5/pcs,
6P14PEV - 5500 pcs. for $12/pcs,
6S3P - 400 pcs. for $1.5/pcs,
6H2PEV - 2500 pcs. for $1/pcs,
6H6S - 800 pcs. for $1/pcs,
GU50 - 6000 pcs. for $4/pcs
- Vendor's Bazaar
- Various tubes for sale
