Some LM317, surface mount SMD on the Ebay
20 X SMD IC LM317D2TG LM317 1.5A Voltage Regulator Design Kit New TO-263 D2-Pak | eBay
Edit
A one NOS Photodiode
http://www.ebay.com/itm/251071504166
Edit
Russian Tetrode tube on the Ebay
50 PCS Russian Military Grade High Voltage Vacuum Tetrode Tube 6E15P NOS 6?15? | eBay
820pF x 160V film foil capacitors NOS
3Pcs 820pF 160V KC1848 ERO Polycarbonate Film Foil capacitor Audio caps NOS | eBay
Ferrite Inductor coil
Mini Lead Toroid Inductor Ferrite Core Choke Coil A lot of 20 | eBay
a little more of 0.022 x 400V for audio DIY
500x 0.022uF 400V KC1849 Polycarbonate Film Foil ERO capacitor Guitar Audio Tone | eBay
Some new items on the Ebay
SMD fuse 125V 2A
Fuse Schurter OMF 125 F 2A 125V ULSM SMD IR100A /125VDC / 125VAC LOTS OF 100 | eBay
Optocoupler a lot of 100
TCET1102G Optocoupler, Phototransistor Output High Temperature a lot of 100 | eBay
Relay 12V / 250V 8A from FEME
Feme M15M A H 001 8 12VDC 250V 8A relay relais a lot of 10 | eBay
SMD fuse 125V 2A
1000uF x 6.3V in the factory box
Panasonic Aluminium Electrolytic capacitor 1000uF 6.3V 105C box a lot of 500 | eBay
Once inductor on the Ebay
Mini inductor ferrite core choke coil with wires Green Red A lot of 100 | eBay
I Can also provide any components ,even paper oil capacitors
MKP and any high qulity part,old stock silver mica -superb caps
Thank you for offer, but I'm selling my own items
Some capacitors 220uF x 385V a lot of 50 for tube projects
BC Vishay Aluminium Low ESR Capacitor 220uF 385V in the original box a lot of 50 | eBay
Some new items are available on the Ebay
0.0068µF 6.8nF 1600V 1,6kV 5% Russian Military PETP Capacitor K73-16 lots of 108 | eBay
BAS16LT1G BAS16 SWITCHING DIODE 75V 200mA SOT-23 ON Semi a lot of 1000 | eBay
4700pF 4.7nF 160V KC1849 ERO Polycarbonate Film Foil capacitor NOS lots of 1000 | eBay
1800pF 1.8nF 400V KC1849 ERO Polycarbonate Film Foil capacitor NOS lots of 1000 | eBay
2700pF 2.7nF 400V KC1849 ERO Polycarbonate Film Foil capacitor NOS lots of 1000 | eBay
3000pcs BC807-25 General Purpose SMD transitor PNP switch SOT23 45V 0.5A | eBay
ICP ACE-716C 150W Power Supply 24V DC to 5V 12V Voltage Reducer for Truck Car | eBay
Vishay Elko Aluminium Low ESR Electrolytic Capacitor 220uF 385V a lot of 100 | eBay
Evox Rifa 470nF 0.47uF 250V MMK15 Polyester Radial Capacitor Kemet a lot of 600 | eBay
SSR Zero cross turnon 5A 3-15Vdc 240Vac Solid state Relay HFS41 a lot of 10 | eBay
Nichicon 47uF 100V Electrolytic Capacitor High 105C Low ESR Japan a lot of 500 | eBay
Some Jamicon Fans 40mm
Jamicon rotary FAN brushless 40mm 5V 0.8W 5400RPM 5.75CFM KF0410S5M a lot of 10 | eBay
Some new items:
TE SCHRACK RT1 PCB RELAY RT314730 SPCO 16A 230 VAC Non Latching a lot of 10 | eBay
3,000 Zener Diodes 30V 1W Zener Fairchild Semiconductor BZX85C30 | eBay
W04G 400V 1.5A Bridge Rectifier General Semiconductor a lot of 20 | eBay
MST250 GS Non-resettable fuse Time-Lag T 250 VAC 400mA Schurter a lot of 50 | eBay
PHILIPS ZENER DIODE BZX79B30 30V 400mW a lot of 9,500 | eBay
BTA208 800B Series B NXP 3Q Hi-Com Triac a lot of 50 | eBay
Hi
Yes, they are
Also they are good for paint, too
Thanks, made an offer.
- Vendor's Bazaar
- Various NOS and Military Grade components for sale
