Vandergraff Nautilus 2000D
Hello everyone, I am repairing this amp, do you have short the psu irf3205 mosfet and the output mosfet in the output takes all irf1310n, will it be alright if I carry those? use hip4080ipz, how many mh should each output coil approx measure around 120mh?
I've seen the 1310 work in some amps but the only FET that I've seen work in all of the 4080 amps that I had to repair was the IRF3710Z (Z is critical).
If both inductors read approximately the same value, they're likely OK. Very few diagrams give the inductor values and when they are given, the values rarely match what's in the amp.
