Tief or anybody else
Do you know which laser head sits in CDM Pro VAU1255/21-LF and best source for it?
under
https://www.hifi-advice.com/blog/cl...lips-cdm-mechanisms-page-3-cdm-12-and-cd-pro/
I read the follow:
The CD Pro 2LF is the final generation of the CD Pro family, where LF stands for Lead-Free. This latest version is essentially the same as CD Pro 2M, except that it now conforms to European RoHS hazardous materials standards. The CD Pro 2LF is produced using lead-free components and a lead-free soldering process. Hazardous substances like lead, cadmium and mercury have been eliminated – even the connectors are now gold. The CD Pro 2LF did get a new microprocessor and still delivers the same performance as CD Pro 2M.
CD Pro 2LF can be identified by the blue connector on its back (label) side. The label on CD Pro 2LF will read “VAU 1254/31LF.”
For as long as stock lasts, Enco still sells a version of the CD Pro2LF designated as “VAU 1255/21LF.”
This module remains fully compatible with its predecessors.
It’s model designation reflects the fact that it is essentially the “base module,” without an extension plate or mounting & suspension hardware.
Enco also still stocks all the necessary parts to bring this module into “full trim.”
VAU 1255/21LF can directly replace the CDM12 Industrial, CD Pro, CD Pro 2 or CD Pro 2M in any existing application. It has the same footprint and dimensions and can be equipped with the same mounting and suspension system. It also maintains the same electrical connections as the preceding versions. In other words, one should be able to replace a CDM12 IND or any of the CD Pro modules with the CD Pro2LF in their existing application without any problem.
This means, the head is the same than the head from VAU1254/31LF.
Ask there for more details:
Enco Systems Inc.
24301 Majestic St
Oak Park, MI 48237
248-541-6300
https://encosystems.net/product/opu2-optical-pick-up-unit-for-cd-pro-2/
I read the follow:
Enco Systems Inc.
24301 Majestic St
Oak Park, MI 48237
248-541-6300
