Valve pre amp/phono stage
I wish to build a valve preamp, from either a kit or from semi scrath with some known circuits.
The pre amp will be used with 4 x500watt mono blocks.
It needs to have volume, source selector and phono stage.
(including mm or mc)
Any ideas?
Thank You
Consider the Aikido kits from J Broskie / TubeCAD. He supplies line stage, voltage reg, phono and attenuator kits. They seem to be well received.
(If you ask a moderator to move this thread to the Tubes / Valves section of the forum you might get more answers!)
