diyAudio is a great forum, plenty of kind people like you Salas always helping the others with the projects.
Itch is a top notch valve phono amp.
Was and long and winding road...
Congrats to you and for making and to the members for being helpful to each other
The Itch can adequately amplify HiMC or MM cartridges but not MC without SUT or active pre pre like this
OK, thank you for answer Salas! And for MM? Any solution without SUT, cause high costs? Have an Empire 999 from 1971.
Answered here Salas post 3179 Valve Itch phono
MM and HiMC can be connected directly to the Itch without any SUT or Pre-Pre. It gives 45dB voltage gain at 47k input load when driven directly. That's stated on the schematic also. You just delete the SUT from the schematic and its simply an MM phono.
Thank you Salas! That encourage to start me to build up the itch 😉
Good luck with your building.
Thanks 🙂, any suggestions about 260vac transformer?
I use Lundhal LL1683 250VAC
sounds good. The same for filaments as well or they are saparate?
The same Lundhal for all Itch.
ok, and what you are using for maida 300v? Planning for test to use varistor and replace them later to...?
Back In The U.S.S.R. ... Baby !
Lookin' good Gatisozo.
I have some Ruskie metal-canned polystyrene capacitors ...
... they are THE ONLY bits which remain stable ! 😉
I think those silver-micas are a GREAT choice for 'The Itch' E.Q.
I want some ! 😀
Si.
I want some ! 😀
Si.
- Analogue Source
- Valve Itch phono
