Valve Itch phono
Joined 2009
I always trusted in the combo TT & valve pre, is the way I start my love to music 30 years ago.
I'm tempting to refurbish my mono blocks Jadis JA-80, could you help me? I will post in the valves forum.
Now I'm ready to finish my 26# preamp;)
Attached Valve Itch pic
Joined 2009
I followed Fran's grounding, star ground, ground wire coming from PSU not direct to star ground: between them I use the ground loop breaker. I learned doing other valve phono preamps it's very important twisted wires & for heater & B+ wires don't cross or be near between them, heater wires also must be always near chassis so chassis acts like a shield avoiding noise in the heaters. Heaters regs I used PRP resistors, BG NP & Panasonic FM. Only boutique parts are used in the phono:
Resistor 22K B+ between 6SN7 & 6N2P-EV (Mills+Shinkoh)
Load cartridge resistor 47K (Audionote tantalum)
Resistor R3 47R Takman carbon
Rest of resistor are common cheap carbon
Heater elevator cap 1uf 450V Auricap
Output caps 3.3uF 450V Auricap
Step-up resistor Shinkoh
Ground loop breaker used
Attached pic, enjoy.
Arrh !
You make 26 as well Felipe !
I looked at this also...
...good with attenuator between Itch & 26 maybe.
Felipe...You told me a year ago...but I forget...
...You are using 'balanced amps'...yes ?
..I think you built yourself Nelson something ( F? ).
What line-stage do you use/build ?
This is what you listen to 'Itch' with now...before amps/s ?
Si.
Hope that makes sense.
( nice grommets !!! )
Joined 2009
TT gnd it's only connected to chassis, the gnd coming from separate PSU goes to the ground loop breaker so you have a clean ground star without any ground loop where to connect all grounds, see attached pic.
