I picked up a small Sony R-R that used this tube in an SE output stage (and a 3rd one in the head driver amp?). I'm guessing it is one of those rarish single manufacturer Japanese tubes... does anyone know anything about them. Of primary interest is what the likely primary would be on the OPTs.
It also used 6267s on the front end -- i gather this is an EF86 variant.
dave
dave
Dunno about the NEC tube but :
Yep. The direct equivalent would be the EF806S which is the SQ version of the EF86/6CF8?
The Soviet equivalent is the 6(shh)23Pi.
Cheers,😉
Cheers,😉
30M P25
I will have to dig through my old stuff, but from memory it is a 30 volt heater pentode made by Matsushita. Sony machines tended to use low volts HT so out impeadance about 3 K Ohm. 2 watts output.
Re: 30M P25
That jives... the HV tap on the trafo is marked 140V IIRC. And 30+30+30+6.3+6.3 = 102.6 V -- pretty close to what you'd expect for a series string
3K 2 W would make it suitable for 50EH5 or 50C5 spud amp.
dave
AV8R said:I will have to dig through my old stuff, but from memory it is a 30 volt heater pentode made by Matsushita. Sony machines tended to use low volts HT so out impeadance about 3 K Ohm. 2 watts output.
dave
