Valve/chip amp hybrid project.
A new project using cathode follower valve front end with a TDA9274 chip amp.
The valve uses +/-335VDC for B+.
Heater volts are dropped to 12VDC using two resistors from +35VDC.
Hi Nigel,
I've just bought a pair of these off Ebay and should have them connected up today or tomorrow.
I may have to reduce the gain to 24db, the minimum allowed according to the datasheet as I have a couple of 12AX7 valves which have a higher gain than the 12AU7. (change 680r to 1.5k)
My psu is in a separate enclosure connected via a 1m cable with 3pin XLR connectors because I will also be using (not at the same time!) with a Krell KSA50 clone module due from China in a few days.
I've just checked my mains and its a bit on the high side at 248v off load, 244 with the cooker on full so my 25v toroid will produce about 37v off load, 35v loaded.
I'm doing an auditioning comparison of the hybrid chipamp, the Krell and a 30watt Class A PP 6L6GC tube amp I am building.
My speakers are Martin Logan Aeons which are hybrid electrostatics and a tricky load for any amp. Probably I end up using the chipamp to drive the bass unit. and the 6L6GC amp for the electrostatic panel.
A JLH high power (ELS) Class A amp wasn't upto it and nor was an EL34 PP VR70 (Dynaudio) budget tube amp.
Ian
PS it would have been good to find the insulators supplied with the pcb.
That was my initial plan until I spotted the 24db min gain requirement.
I definitely don't want a 100w power oscillator - had one of those with a chinese power amp "no feedback" design. Except it wasn't, they just didn't bother with the feedback resistor so anything connected to the input caused the output to bounce off the supply rails at 100khz.
Fortunately I had thought to use a dummy load or my speakers would have been toast.
