Hi guys,
Can you recommend or add your wisdom and experience to what constitutes a good valve base.
I need valve bases that will sit on top the chassis.
I have been looking at various ones but there are a lot to choose from , silver, gold, Belton Micalex, Audio Note Silver, bakalite, Teflon, ceramic
8 pin for 12AX7, 12AU7 etc
9 pin for EL34 etc
9 pin for EL34 etc
Sorry but those are real hard to find8 pin for 12AX7, 12AU7 etc
9 pin for EL34 etc
12AX7, 12AU7 etc are 9pin B9A bases. Not 8pin I use RS PRO, Thermionic Valve Base B9A for 12AU7, 12AX7, 6DJ8, 6L13, B329, B339, CV491, CV492, E88CC, ECC82, ECC83 | RS Components
EL34 is International Octal or 8pin. Not 9pin I use Thermionic Valve Bases | RS Components
A 9 pin version of the EL34 would be called EL60 (enneal base).9 pin for EL34 etc
Best regards!
