va ratings for ucd180
i built a powersupply for 2 ucd180 modules.
2 xformers rated @2.35a each with secondaries of 27v.
each xformer feeds a full-bridge monolithic 25a metal-case rectifier.
each rail is 27kuf and measures 40v +/-.1v
the caps are seriesed for the +/- rails.
everything is great until i start to really crank the volume.
right when it starts getting to where i think it sounds really big the amps start momentarily shutting down.
i started to think they were clipping but i heard no distortion prior to them shutting down.
they shut down during the loudest transients for only the duration of the transient.
i know i have enough capacitance but im starting to wonder if i have enough amperage.
is my psu running out of amperage ?
2.35a x 27v = 63.45va per rail right ?
ive been using an old mitsubishi 2-channel amp and it plays plenty loud for me and i think its rated at only about 60wpc.
i was hoping i would be able to go loud and keep all the great stuff that the pwm amps do.
i have a pair of hugeass 11a@27v xformers i could use but didnt want to build a larger psu if that wasnt the problem.
thanks
just thought of this.........the psu is
outboard and connected with a 5' cable of 14awg 3-conductor.
ive used a similar setup with other amps with no problems.
could it be a problem for the ucd180 ?
or is the low va most likely the cause ?
thanks.
