I have made a V76 type mic pre with a White follower output stage. (2x EF86, 1x12BH7). I have basically copied the first stage of a V76. There are 2 problems I need help with as Iv'e been working on this for months and I need fresh ideas! First problem is a very low frequency (about 2Hz) on the output which unless I have a 2k resistor across output ,spoils the 90dB S/N ratio. second problem is that the Bass rolls off from 100Hz to about 3/4 of 1KHz value by about 40Hz. Otherwise frequency response is flat to 35KHz.
By the way, I have translated from the telefunken braunbuch the technical descriptions for the V72,V77 & V78 circuits. I would be happy to place them somewhere accessible for members but I don't know how, this is my first ever post!
all the best
Dave P
all the best
Dave P
Dave,
welcome.
Shall I move your thread to tubes or analogue?
If the Telefunken descriptions are not copyrighted material, you can host them here if the files size is <100k and max 800X600 pixels.
/Hugo
welcome.
/Hugo
Hi Hugo,
I 'm not sure where to post, I'll be guided by you.
There are 3 pdfs of about 50k each, I did the translation so the work is mine and I got the German version freely off the web, what do you think?
best
Dave
best
Dave
Dave,
50k will be no problem, you can only attach one file per post.
I'm looking forward to read them.
/Hugo
/Hugo
Now I know what my EF804s were for! The screening on the mains transformer is to protect other circuitry from the extraneous field it generates, not to protect the mains transformer.
I await diagrams with interest.
Thats right, this is one of the reasons why they managed to obtain such amazing S/N ratios (~120dB). Although the tubes are not canned, the steel chassis wraps around the tubes quite closely as well. The Mains TX screening stops the mic TX picking up hum in such a confined space, the components are really packed in.
Dave P
Dave P
It seems that money was not a problem for people building and buying V76s and such back then. Did you ever see the input transformer? Also, all the metal is expensive mumetal including the amplifier case and covers, as well as all the transformers shields. The input transformer has very big cobalt-core (permendur) and a nice 10 layer copper/mumetal shield and had also 10 section bobbins!!! I don´t know anything even close to this type of engeneering at any time.
EC8010 said:Now I know what my EF804s were for! The screening on the mains transformer is to protect other circuitry from the extraneous field it generates, not to protect the mains transformer.
Hello ,
here are the links to nearly all "Braunbücher" and a link to the Klangfilm amps .
http://www.kubarth.com/
http://www.irt.de/IRT/home/indexpublic.htm
http://klangfilm.free.fr/index.php?lng=0&music=&type=0&frame=0&item=&title=&dir=&num=
And here is a picture from a friends mixing console with a TFK M5b .
Telefunken made many descriptions , like their tube data books , in both languages , english and german .
Regards , Alexander .
