V2 Speaker upgrade options
The new V series speaker kits from CSS are available with many options for each speaker kit
V2 speaker kit which uses a pair of VWR driver in a MTM configuration in a mid sized monitor.
For those not listed on the CSS site please contact for pricing
CSS V2 speaker kit acoustic foam damper pads
CSS V2 speaker kit Mill resistor upgrade
CSS V2 speaker kit Mills resistor upgrade acoustic foam damper pads
CSS V2 speaker kit Obbligato capacitors with Mills resistors 16g teflon wire Acoustic foam,damper pads
CSS V2 speaker kit Obbligato capacitors with Dueland resistors 16g teflon wire Acoustic foam,damper pads
CSS V2 speaker kit Obbligato capacitors with Mills resistors 14g DHLabs wire Acoustic foam,damper pads
CSS V2 speaker kit Obbligato capacitors with Dueland resistors 14g DHLabs wire Acoustic foam,damper pads
CSS V2 speaker kit Mundorf EVO capacitors with Mills resistors 16g teflon wire
CSS V2 speaker kit Mundorf EVO capacitors with Dueland resistors 16g teflon wire
CSS V2 speaker kit Mundorf EVO capacitors with Dueland resistors 16g teflon wire Acoustic foam,damper pads
CSS V2 speaker kit Mundorf EVO capacitors with Mills resistors 14g DHLabs wire
CSS V2 speaker kit Mundorf EVO capacitors with Dueland resistors 14g DHLabs wire
CSS V2 speaker kit Mundorf EVO capacitors with Dueland resistors 14g DHLabs wire Acoustic foam,damper pads
