V-M 8810 Rebuild. Safety Reassurance.
So I did the short plug. I honestly couldn't tell any difference. Another observation I mae is I get some weird nuances while sweeping the volume knob. Almost sounds like sweeping a filter from low to high. It its not a uniform "sweep" so to say.
When the 'phono' input is utilized the sound is more consistent. No funny effects from the knobs. I dunno, maybe it's my guitar. I did notice however that the hum is more prevalent when the bass is boosted.
As I think I mentioned earlier (or maybe it was in another thread) instrument amps aren't something I normally deal with and so I did a double take when I looked at the mic input on the diagram in post #1
It looks like the MIC socket has an extra connection that the plug barrel uses to add a 0.47uf cathode bypass into circuit, presumably to give some HF lift. Never seen anything like that before.
The phono socket does appear to have a shorting option now I look closer although that input is still 100's of k away from the MIC input.
I suspect the hum and all is normal.
Yes, the extra finger on MIC does "something". It may kill NFB, or reduce the tone-control range. I'd have to work-out that odd tone/NFB leg, and I'm not up for that.
If this will be "only" a gitar amp, I'd cut a lot of that phono network right out. The amp already has a "design flaw": vol pot at pickup level. This means you get (nearly) all hiss and all hum all the time, even when turned-down. (You may turn-up the hum around the jack and pot and the pot hiss.) There were a few commercial g-amps which did this (not "good" ones). Look at any of the Fender Champs (similar tube lineup), Leo put the vol pot between 1st and 2nd stages. Turn-down lost 1st stage noises.
I would not go back and hack the V-M with vol pot between stages. You want that, Epi Valve Jrs (Champ clones) are readily available. The V-M gain-staging is "different", and with the world over-run by Fender(/Marshall) clones, we need to preserve those differences for future players.
