V-I limiter problems
I've been trying to add a V-I limiter to an amp design but I can't get it to work properly in the simulation. It's intended to limit the output current to 8A and it is doing that on the positive half-cycle. However, there is no effect on the negative part. I can't figure out what the problem is. Any ideas?
Thanks,
James
It could also blow up Q7 and Q15 (R13, D4) during current limiting, and Q6 during clipping.
Any emitter resistor you add to Q7 will aggravate the right-half-plane zero that destabilizes the feedback loop. I don't know if that is bad enough to be an issue. If it is, you could connect a resistor with equal value in series with the Miller capacitor or put a relatively small decoupling capacitor across the emitter resistor.
