UTC2050L
Evening all, Found these at a local place, I have run them on +-26 VDC, they seem to work fine. Looks reputable ? UTC ?
Any experience on these chips. Had a Sony 212 to repair and the original chips are long gone, LM1875 chips were not available at that moment for an emergency fix, so I used them. Ha1350 were the old chips.I know the old original TDA2050 are not made any more.
Jan
Hi, so you replaced HA1350S in the sony with TDA2050? Can you tell me how you connected that? The original chip has 10 pins. Is it conencted like this?
Does it work in the sony with no problem?
TDA2050 HA1350S
Pin 1 Pin 7 - In+
Pin 2 Pin 8 - In-
Pin 3 Pin 10 - Vcc-
Pin 4 Pin 1 - Output
Pin 5 Pin 3 - Vcc+
