... The setup dspswede is working on is 8/in 16/out. It may be possible to get 8 channel digital in with USB, I think that was what he was thinking about.
The typical example of a 10ch-out interface is the legacy Envy24HT used in many PCI soundcards. Look at the datasheet http://www.hardwaresecrets.com/datasheets/Envy24HT.pdf
The chip offers 5 x I2S output. The last stereo pair (9 + 10) is also routed to the internal SPDIF transmitter, providing SPDIF output for most cards using this chip, but the actual I2S output is still available on pin 106 SPDOUT.
E.g. Revolution 7.1 M-Audio Revolution 7.1 PCI Sound Card 612391991203 | eBay has 8 DACs and the SPDIF output, SPDOUT is unused.
In linux it is simple to merge the 8-channel surround device 3 with the 2-channel IEC958 (SPDIF) device 2
Just hook another stereo DAC to SPDOUT and you have a decent legacy 192/24/10ch with 100% support in latest linux 🙂
Code:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Revolution71 [M Audio Revolution-7.1], device 0: ICE1724 [ICE1724]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: Revolution71 [M Audio Revolution-7.1], device 1: ICE1724 IEC958
[ICE1724 IEC958]
Subdevices: 1/1
card 0: Revolution71 [M Audio Revolution-7.1], device 2: ICE1724 Surrounds
[ICE1724 Surround PCM]
Subdevices: 3/3
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
But his project is still work in progress, right? Also with 8 channels I would need two boards and that would bring up the sync problem again, wouldn't it?
phofman: Thx for the suggestion, but I only have PCIE. Also those cards don't seem to be available any more?
But using a 7.1 card + SPDOUT + DAC is an idea I will keep in mind 🙂
And link the crystals of two of them like described in that link I posted (BTW also an Envy24 card) and you get 20 channels, or 16 channels without adding any DAC 🙂
@ phofman: Thx for the suggestion, but I only have PCIE.
Or getting a PC with PCI (I like using this one Headless Amplifier Measurement Workstation but it would not take your DSP load) , or a PCIe-PCI adapter (there are adapters using same conversion chip as e.g. ESI Juli PCIexpress).
I gave a link to ebay, readily available everywhere. No reason to buy a new soundcard, it does not rotten.
I am not saying you should go this route. Just showing there are ways, and some of them very inexpensive.
BTW should you plan to use one soundcard for analog/digital input and another for output, you will end up with the same multiple-clocks issue.
Yeah up to this point it does seem like the most inexpensive way to get a 16 ch. output. And modifying that clock doesn't look like that much of an effort.I am not saying you should go this route. Just showing there are ways, and some of them very inexpensive.
If Charlie doesn't tell me a better solution, then I will go that way 🙂
Thx a lot 🙂
From Banana UG:
Output A1, A2 and A3 are not exactly synchronized. On Voicemeeter every i/o are independent and we can hear more or less delay between them, especially when using 3 audio outputs: if A1,A2 and/or A2 are routed to 2 or 3 audio devices, the sound might be not exactly synchronized (one speaker output can be late and produce a small echo with other speaker output). This is normal (according technical constraint) but can be corrected by compensate one audio output with a delay line (see System Settings Dialog Box).
A quick follow up question: Does this problem also occur, when the sound cards have the same clock (physically connected)?
Charlie wrote back and suggested a USB Device + ecasound+LADSPA. But the sample rate has to be manually adjusted (if it is known and fixed it is not a problem), but for me it seems like a sub optimal solution.
AFAIK Charlie is working on a new gstreamer-based chain, without the aloop device and fixed-rate ecasound setup. Perhaps you may ask him about that one.
Hard to say without seeing the source code but, I quess, there can be little delay between those devices because of quite often you do things in series ... or you have different type audio interfaces (USB, FW, PCI, PCIe) attached to these ... but that shouldn't be an issue because of you be able to adjust the delays through Banana options.
Ok, I will ask Charlie 🙂
@jiiteepee: But if it is processed in series, wouldn't the first delay also delay the second channel (and therefor not get rid of the problem)?
Depends on where you add this correction buffer (delay) ... I suppose VB does it "the right way".
Will the occurring delay be displayed, or do I have to adjust the delay by hand until it sounds right?
Up to this point the Windows + Banana + EPO solution sounds like the way to go.
(Running Ubuntu here) Probably by ear but, if you play same frequency sine wave through two devices simultaenously it's quite easy to hear when those are in sync.
You may be interested in some of the projects below.
http://www.bodziosoftware.com.au/Hybrid AES_EBU_Analogue_System.pdf
http://www.bodziosoftware.com.au/AES_EBU_Amplifier_Construction.pdf
http://www.bodziosoftware.com.au/AES_EBU_System_Evolution.pdf
http://www.bodziosoftware.com.au/AES_EBU_24Bit_96kHz_System.pdf
Best Regards,
Bohdan
Best Regards,
Bohdan
Funny to find this thread are. I have a similar predicament. I want high-end DAC performance but with more than 2 channels. Most multi-channel DACs use 'meh' chips.
I tested the Voicemeter Banana option with an ASUS Xonar DX running the satellites and using a Focusrite Scarlett 2i2 for the subwoofers. In my quick test it worked ok. My main caveat was that the volume keys only change the main soundcard volume by default.
Solution is to use the MacroButtons feature of Voicemeter.
I've ordered a Topping D10 DAC which looks very promising for the money. Sadly for OP it's only stereo.
Why not use HDMI (8 Channel) and on board soundcard (6 Channel) at the same time. I did not try but I think there is a solution in Linux. Maybe with Pulseaudio or plain ALSA.
For HDMI and X-over take a look here. X-over realized by Laptop, Open Source and 7.1 AV Receiver over Display Port / HDMI
https://1drv.ms/b/s!AnKX4vLSHn4Nh5ty6YD-Ge9iJbJ8qA
P.S.: After short Google take a look here for example Linux & Sound aus mehreren Soundkarten gleichzeitig | Coders Kitchen
I found this theme interesting so I dig a little in web.
ALSA_OUT seems to be a good solution and I gave it try.
I tested it on my second desktop. Not my main DAW.
In KXStudio its only one or two simple lines to add it to the jack configuration.
I have the following hardware interfaces
Intel Analog
Intel Digital (ALC898)
Intel HDMI with 3 subdevices
NVIDIA HDMI with 4 subdevices
I tried out in parallel
Intel Analog conected to a headphone (Hardware Playback in Cadence)
NVIDIA1 connected to a Monitor
NVIDIA2 connected to a UHD television
All in parallel are giving sound at the same time.
The sound is not 100% syncing.
Thats clear because each connection has its own DAC
Intel Analog by the inernal soundcard
NVIDIA1 by the DAC of the monitor
NVIDIA2 by the DAC of the UHD television.
Enclosed the connections shown in CLAUDIA.
So in KXStudio it is not a problem to connenct to all souddevices of your hardware together.
This is also with X-over and other plugins.
Work has to be done is to sync the sound to all devices.
But this also should be possible with the right LVS or LADASP plugin.
Guenter
Code:
"alsa_out -j NVIDIA1 -d hw:2,7 -r 44100 -c 2"
"alsa_out -j NVIDIA2 -d hw:2,3 -r 44100 -c 2"
My aplay -l looks like this:
Karte 0: PCH [HDA Intel PCH], Gerät 0: ALC898 Analog [ALC898 Analog]
Sub-Geräte: 0/1
Sub-Gerät #0: subdevice #0
Karte 0: PCH [HDA Intel PCH], Gerät 1: ALC898 Digital [ALC898 Digital]
Sub-Geräte: 1/1
Karte 0: PCH [HDA Intel PCH], Gerät 3: HDMI 0 [HDMI 0]
Sub-Geräte: 1/1
Karte 0: PCH [HDA Intel PCH], Gerät 7: HDMI 1 [HDMI 1]
Sub-Geräte: 1/1
Karte 0: PCH [HDA Intel PCH], Gerät 8: HDMI 2 [HDMI 2]
Sub-Geräte: 1/1
Karte 1: Loopback [Loopback], Gerät 0: Loopback PCM [Loopback PCM]
Sub-Geräte: 8/8
Sub-Gerät #1: subdevice #1
Sub-Gerät #2: subdevice #2
Sub-Gerät #3: subdevice #3
Sub-Gerät #4: subdevice #4
Sub-Gerät #5: subdevice #5
Sub-Gerät #6: subdevice #6
Sub-Gerät #7: subdevice #7
Karte 1: Loopback [Loopback], Gerät 1: Loopback PCM [Loopback PCM]
Sub-Geräte: 8/8
Karte 2: NVidia [HDA NVidia], Gerät 3: HDMI 0 [HDMI 0]
Sub-Geräte: 1/1
Karte 2: NVidia [HDA NVidia], Gerät 7: HDMI 1 [HDMI 1]
Sub-Geräte: 1/1
Karte 2: NVidia [HDA NVidia], Gerät 8: HDMI 2 [HDMI 2]
Sub-Geräte: 1/1
Karte 2: NVidia [HDA NVidia], Gerät 9: HDMI 3 [HDMI 3]
Sub-Geräte: 1/1
Intel Analog
Guenter
- PC Based
- Using two soundcards at the same time?
