Hello
It's very low-value NP0 caps, two 15 pf in series.
Thank
Bye
Gaetan
The effective capacitance of series connected 15pF capacitors is 7.5pF but parallel connection of two 7.5pF capacitors will give you 15pF effective. So if the actual value is important you have to properly calculate it.
Hello
Is there any differences betwen using two 15 pf NP0 in series vs two 7.5 pf NP0 in parallel for a vas cdom ?
Thank
Bye
Gaetan
Which capacitance do you actually need? There is always a possibility to series or parallel connect capacitors of different values to arrive closer to the target value.
Hello
Is two NPO capacitors in series will share equally the current and voltage ?
Thank
Bye
Gaetan
