Using transformers as choke?
Unfortunately I don't think that mains transformers are suitable for chokes for tube amp PSU's because they are not 'gapped'.
When a D.C. current flows through a transformer, then a D.C. flux is produced in the transformer laminations which suturates the material very easily. For this type of operation, manufacturers produce similar looking cores, but with a small gap in the magnetic path, which prevents D.C. flux from flowing. It's A.C. performance remains OK for smoothing.
Single ended output transformers are similar, for the same reason.
Sorry to be the bringer of bad news.🙁
skyraider,
If you are trying to save money, power transformers salvaged from microwave ovens make pretty good power supply chokes as-is. Use the HV winding and lift the inner end of it off the core or use the choke in the negative supply lead so that the core can be grounded.
Rob
Hi Rob,
Not really want to save money to that extend, its just that many transformers are available cheaply and I am just wondering if it can be used without too much trouble.
For example, I just picked up some 28v-0-28v, 28VA at 4USD. If I would to buy a dedicated choke it would cost many times more.
skyraider said:
Hi Rob,
Well there's nothing quite as rewarding as trying an experiment yourself to find answers to your own questions. If the outcome is clearly not likely to hurt anyone or damage property, experiment away I say!
Multimeter
Some of the gimmicky multimeters have an inductance range, up to around 20H
Trouble is, they are a bit delicate, Ive blown up two already, while my old Beckman has lasted 20 years without mis-hap, and some really distressing service.--Like everything, you pays your money and takes your chances
The Beckman was 300 GBP nearly 20 years ago, while the cheapie 'quality' meter was only 60GBP around a year ago...
Ive been thinking about the chokes from large flourecent fittings, the ones for 8 foot tubes are pretty chunky--Ill have to try some out, as Ive got access to a couple.......
My multimeter measures up to 20henries it was average price at Jaycar or Dick Smith cost $130aus, but I borrowed the shops one which was more expensive at $260aus, Just went through all the plugpaks they had, and got the one with the highest henries on the primary with resonable dcr, for memory it was about 80ohms and the primary winding is rated at 240v 1amp.
Cheers George
Vertical sweep output transformers or autotransformers from vintage B&W TV sets from the 40's and 50's can sometimes serve as plate chokes in tube amplifiers. It may be necessary to place an R in series or parallel to de-Q the stage as a midband peaky bandpass filter sometimes results.
If the set is a round screen 40's vintage unit and is in really nice shape, please offer it to TV collectors on ebay rather than destroy it for a transformer. These aren't being made any more and are getting scarce. If the set is junk, by all means strip it for parts. You will find useful tubes in there too. 5U4's, 5V4's, 6SN7's, etc Grab the power transformer. This can power a nice tube amp project!
Small 120 to 12/24 vac'ish xfmers from microwave oven control panels can also be used as plate chokes, as I imagine wall wort xfmers. Only bench testing will reveal the suitability of a given xfmer.
