Found a Sony HTIB sub for 25 bucks at a second hand store.
Thinking of building a big box and using its amp to run it. Anyone done this?
In its current state it doubles wildly below about 45 hz.
That is possible, thought the amplifier is likely to have specific filtering built in for that woofer: a high pass and possibly a low frequency boost. It will require some modifications.
definitely check it for a high pass. whatever you plan to build, simulate with whatever the filtering on the amp is.
