Ok, i'm doing the PC mod where you add a psone lcd to your pc case and run cloned image on it.
now how can i use power strip to choose the settings to stabilize the lcd only and not my other monitor.
I'm using an ATI 9800 radeon pro. and the catlyst program seems to only let you choose either Dual clone mode, where i tell it that it's a tv. (i have to cause i have it hooked up through the S-video to card)
is there any ways to use power strip to change my settings for the psone lcd only?
my image is ok, but has a lot of interference lines, is this cause it's hooked up RCA? i don't feel comfortable soldering the VGA cable on. and even if i did that. i would still have to use power strip to find the native settings for the LCD and thus SCREW up my regular monitor settings, right?
thanks.
thanks.
