Hello everyone,
I have a Casio CDP-230r piano which only has one output (1/4) port which is also the earphones port. Whenever I use that as a line output to the stage speakers the pianos built-in speakers stop working, which is how its supposed to work. Is there anyway that I can still use my pianos built-in speakers and output my audio signal to the stage speakers at the same time?
I know that I can also split the signal and use a stage monitor instead but I would like to see if there was still a way to use the piano speakers.
Thanks in advance.
Thanks in advance.
Same thing happens for smartphones, and speakers with headphone out...
These use 3.5mm connectors with switches. Plugging in the plug disconnects pin 5 from 2 and pin 3 from 4. Just connect the pins elsewhere if needed.
