using pc-powersupply for fans.
I have an old pc that i can salvage the power supply so i could use computer fans off of it.
but how can i make the fans run automatically when it's plugged in instead of requiring a mother board to push the button on?
any suggestions?
i know some of you spoke of soldering power wires to the driver board of the lcd but this is risky and a bit out of my league since i'm not sure what to identify as a suitable connection..........
is there a way to trick the power supply to always supply power when plugged in to the fans i plug into it?
On a modern supply there will be a green wire next to a black wire on the 'big' motherboard connector. Plug in the power supply. put a jumper wire from the green to the black. Unless something crazy happened, the fan should spin.
ok, i took the power supply out, the huge connector that goes to motherboard does have a green wire in that huge number of others.
what exactly do you mean by jumpers? are those the small connectors like that go to back of drives?
so i need to cut the wires from those and stick them into the green wire of large mother board power supply?
oh and if there is minumum load limit, then i could trick the power supply by running all power from the wires that go to the own power supplies fan..... right? or i could just hook up like 3 or 4 fans, (me and my friend have a bunch cause we use to build clone computers so we could have good gaming machines... but i guess you can tell we're not too talented in the extreme modification... (we just plug **** in and hope for the best)
