Using part of my accumulated stash RadioShack 40-1299A
diyAudio Member
Joined 2007
Just in case somebody here has already done the hard work.
Would anybody have the values for the cored inductors in this old RadioShack 3-Way crossover?
I am assuming they are book values for 8R drivers but just in case they are not.
I an trying to insert a 100mm midrange into a big 2-Way and wondering if I can utilise this old unit and not go out and order more parts
It looks as though you could work it out from the information in the manual?
I thought so and I wish this picture would zoom better. There are a few different ways you could measure.
Instead here's a thought. What if you assumed the filters were either 0.5 or 0.7 and they were designed for eg an 8 ohm resistor. This would let you use the capacitance values to work out a specific range for the inductor values?
I may have the RadioShack book by Weems somewhere [ most probably in the shed] so if I know the XO frequencies I can work it out.
XO points will be a lot higher than I usually use but I may be able to use it for the midrange to tweeter divide, save me going shopping.
I found the old RadioShack book
XOs at 800/1600 and 5k/7k
Basically unusable for what I want to do with 8R drivers. However I may be able to use it in the future with some of those throwaway 70mm HTiaB drivers that seem to multiply in dark corners. Not worth listing for sale in eBay without the boxes and paperwork
If I can find some cheap panels it might be "fun" to use this XO as it is and build one of those old speakers just to have on the shelf as a comparison model. One of those that had the bass woofer and the mid woofer sharing the same box perhaps even.
I do happen to have some of those old drivers sitting around after all.
