Using only one channel of a PAM8403 module
I'm going to use one-half of a PAM8403 module as a part of a larger system. Its job is to produce short bursts of a fixed tone. I have two questions about this:
1) Is it OK to leave the unused output pins open?
2) Is it best to short the unused input pin to ground?
Thanks. I've been designing electronic circuits for over 50 years but have been away from audio for a long time. Besides, I've had only a limited experience with Class D amps and this will be the first time I use an off-the-shelf module of any kind in my designs.
