You are allowed to connect ONE end of the mounting bolt to the chassis. The dish usually formed in the big washer is there to keep the bolt head from projecting above the transformer insulation. This helps by preventing the case from touching the free end of the mounting bolt however the washer is still exposed to contact. The case or other chassis metalwork must NOT touch the washer or bolt head.
You could add a layer of insulation over the top of the washerplate and bolt head to prevent inadvertant shorting of bolt to chassis particularly while dismantling or assembly with power on (dangerous pastime).
A shorted turn is a complete electrical circuit from the bolt bottom to the chassis to the side panels across the top (lid) down through the bolt head back to the bolt bottom. If this circuit is completed then the turns ratio of the transformer becomes about 200 to 1 and although only a small voltage is generated, maybe 1/2 to 1 volt the resistance is very low possibly 1 to 10 milliohms the current could run to KA in parallel to the true secondary winding and will definitely overheat your transformer.
