Using electrolytic caps in bass xover
Has anyone able to detect any significant differences in using electrolytic caps in the bass xover in a 3way design? The xover will be a 10mh inductor then 68uf electrolytic to ground. I plan to bypass it with a good 1uf cap. The money saving will be significant. A 65uf electrolytic cap is less than $2 vs much more for a MKP cap with the same value.
When it exploded , I sniffed some significant evidence !!:usd:
But it was a tiny 6.8 µF/ 50 VL ...Bipolar of course !
You can try also regular non-bipolar Electrolytics put in anti-phase series ( +--+ ) ,but in this case you need to find 140 µF values ..
No need for any bypassing , in that position ( and task ) .
Use electrolytic caps with the highest voltage rating you can find 100 V is probably OK; 35V probably isn't.
I no longer bother with the bypass caps as the reactance time of different types of cap is different may have an effect/affect on the sound.
Rather than use a single large cap of the correct or nearest standard value I try and use multiples of the same value in your case #3 * 22uF may work out cheaper and 66uF is probably close enough
One issue is that the stated value on the capacitor's jacket and the actual value probably will not match very well. Some can be as much as 20% off.
The second issue is that electrolytic caps change value over time, which will screw up the crossover. So even measuring them now doesn't mean they will be anything like what you expect later on.
