Peter, there was discussion here of 'snubber' networks across diodes a while back - worth rereading.
Eric.
Eric.
Re: 43CTQ100
Datasheet : http://www.irf.com/product-info/datasheets/data/40cpq080.pdf
Should be no problem, but u may not be comfortable with the margin (I'll be using the 43CTQ100 for the Aleph 5 PSU). It's better than ultafast soft recovery diodes as it has no reverse recovery.Peter Daniel said:Can it be used with rails +/- 45V DC?
43CTQ100
I have never got Schottky diodes to sound as good as soft recovery types. I also don't think 100 volts is sufficient margin.
