In my power supply for a ground grid pre-amp; I use bridge diode rectifier and LCRCRC filter.
Could any one told me if I using a choke of 10H - 200mA in a LCRCRC filter supplying a load requiring only 10mA. Will there be any problem.
i.e. What is the drawback of using a choke with much higher current rating than required?
The choke will not act as a choke input unless Icret is met. Icret is when enough current is drawn in that the capacitor following that choke does not charge up to 1.4 x the choke input voltage. To meet Icrit, you will need more load (current) thru the choke with a large bleeder resistor. How about a new Hammond HC154G for $8.50 You could probally sell the large choke for more than that.
How about if I change the choke input to capacitor input. Could the choke work in this case.
How could I determine the value of the Icrit if the rectifier output volatage is about 230V and the working current is about 8mA?
It was mentioned in another thread some time ago (which I cannot trace now), that choke-input filters are not really used for pre-amps.
Firstly the choke needs to be of a minimum inductance inversely proportional to the current drawn as said, and secondly the normally low current needed and available B+ voltage make the use of CRC filters so much more convenient. And even if the designer is a perfectionist, high voltage semi-conductors for series elements are available at a fraction of the cost of a suitable choke, that can really reduce ripple to academic proportions.
There might even be high voltage IC regulators on the market, although I do not know of any. Are there?
I use choke supplies for preamp. Many have done this. Size of choke is not prohibitive. For an easy way to calculate the choke you need, try this:
www.hagtech.com/theory.html#choke
jh🙂
jh🙂
hagtech said:I use choke supplies for preamp. Many have done this. Size of choke is not prohibitive. For an easy way to calculate the choke you need, try this:
jh🙂
WOW! Those are incredibly helpful calculators! Thatnx for the link.
