I purchased some Blue Alps (50k and 10k) to be used for various pre-amp builds. They seems to be "good enough" for "high-end" use so I don't have to spend 400 USD for e.g. a Khozmo every time (used that for BA-3 pre). But I was a bit surprised how bad the channel match are in these Alps. Only one of the 10k is spot-on. So what do you do? …..just use them without checking the channel match and close the eyes? 🙂
For the 50k stereo pots a typical variation between channels if I set at 1 o'clock is something like 12.7k and 12.3k …. 0.4 k difference out of 12k ….so that is 3-4 %. I think that is a lot? ….I have not calculated what that relates to in dB between channels…...so maybe I should do that before complaining to much…...I would like < 1 dB channel error.
Are "stock" Blue Alps "Pass Lab certified"?
next time buy 100Klin , shunt viper to gnd with 22K and you'll have much better tracking and better LOG transfer function
Potentiometers (Beginners' Guide to Pots)
It seems Alps only guarantee <2-3dB tracking error.
Good idea with 100k Lin and shunted wiper. Then I have to find a good quality 100k lin. It seems Alps don't specify lin/log so I assume they are all log.
The tracking on these seems quite good (if we can trust his measurements):
DACT Type 21 Stepped Attenuator Potentiometer 50K for Amp/Preamp, 2A3, 300B... | eBay
I have never seen such a small stepped attenuator.
I could not resist…..so I ordered 2 pcs of the 10k version. If source can drive it the lower value should be the better choice.
But I think they have "stolen" the name from the "real DACT"?
DACT - Danish Audio ConnecT
You need to measure the attenuation instead of the absolute resistance value at the wiper, because the resistive elements may vary by up to 10% or more, and the attenuation may still be better than that.
In practice, the ratio Rwiper/Rtotal will give you the attenuation.
I'm pretty much same clueless in Law and Medicine .... but that doesn't mean that there are no laws and cures
first rule of Engineering - you need to learn where and how to find and extract needed information
Yes, but higher risk of contact rectification induced distortion.
The above mentioned 50k. One channel measure 47.1 k and the other 47.5k (why do they call them 50k pots?). But the error from wiper to one end is not consistent. It depends on the wiper setting. So I can not just add a 0.4 k resistor to the resistive element but I may be able to correct the error a bit.
A typical setting measuring the side that goes from 0 - 47k:
34.5/47 = 0.734
35.2/47 = 0.749
So with 1V in I get 0.734V out in one channel and 0.749 out in other channel. Relative to 1V it is -2.69 dB vs -2.51 dB ….so that it not much of a difference.....?
It is at least something you can measure…….compared to if an interconnect cable is slivered or not? 🙂
Wait until you're confronted with contact rectification, resistive element composition (carbon/cermet/conductive plastic), wiper geometry, and so on, and you still have to wire it up with OFC/silver/litz/solid core..., and solder with Sn/Pb/Ag.
Dealing with the unknown is a lot more fun! 🙂
Ok.....then this Einstein quote fits?
"Not everything that can be counted counts, and not everything that counts can be counted"
But we have to remember this is "audio"......not atom physics…. 🙂
Perfect fit for quantum physics, audio, cooking, motorsport... you name it 🙂
That is, if you care enough!
My opinion.
I tried the DACT attenuator, it felt nice with soft clicks.
However I found the larger ones with Dale resistors sounded cleaner. (To my old ears)
I use twin mono ladder type as passive attenuator between music server and F6 amp
https://www.ebay.co.uk/str/ATOPELEC/DALE-23-Step-Mono-Ladder-Type-/_i.html?_storecat=3427425219 (Other suppliers are available)
They have a lot of good stuff in that ebay store.
To mono pots......if you can easy see each step then it could be a good solution.
My opinion.
from experience - I don't trust these switches , unless I didn't opened it and put some quality grease in ( Vaseline at least)
some of them even need patient de-burring of all edges inside , or you'll get no contact situation in less than a year
I'm using 2 section/24 position ones for my Iron
however - they're cheap , just buy more 🙂
- Using blue Alps as vol control
