Using batteries for plate voltage
See if you can pick up a dynamotor on ebay or from an old ham. They ran in lead acid batteries and they turned out high voltage by running a 6, 12, or 24 volt motor to turn a generator. It's stupid simple, and they are built with all the quality of 1950s American made stuff!
Theres no reason you cant put a lithium battery in front of them instead of a lead battery. The filtering of the noise should be easy with modern film caps, and I the end will probably make less noise than switching packs in and out of your supply for charging.
Ive heard from those with experience that the dynamotors have a built in inertia cap. When the load sources current the armature has momentum to carry right through it...
Worth considering...
