Using balanced mic cable as signal/DC power?
There's two different applications here and two different sets of safety issues. One will kill you, the other will burn your house down. Let's be clear here. There are withstand voltage specs and usage specs - they are different.
Also you should consider the function of a shield - it prevents capacitance coupled voltages but has no effect on magnetic/inductive/current fields.
B+ is usually very easy to filter as you can afford 10's to 100's of ohms so why shield?
Shielding heaters is not effective due to low voltage. Twisted pairs eliminate the magnetic field.
