I have a non working Yamaha RXV 671 audio video receiver with me. Though its power supply works just fine.
I want to use the power supply of the AVR to power my class D amplifier say TPA7498E or TPA3255.
Is that possible? from service manual I was able to figure out it gives 12V, 5V for some components of AVR out but I am unable to figure out output voltage for Power Amplifier. Is it a overkill for Class D amplifier.
Can someone please guide me on this?
Thanks,
Simar
Thanks,
Simar
I guess most probably not. Those Hifi Receivers are usually working on a symmetric power-supply unit internally. The 12.5V are most probably only for some infrastructure electronic like control-boards oder DSP boards.
But you have to send us some further photos so that we can better judge.
If in doubt, the rating of the big filter caps should give a clue, but given that this is a 105 W / 8 ohm unit, I'd expect the main rails to be +/-55-60 V unloaded or so.
BTW, let me guess: failed HDMI board? Or has a power amp channel called it quits? (Or just a bad standby power supply, a typical Yamaha disease?) I'd be more inclined to be recycling PSU + power amps together... these have notoriously sagging power supplies with all channels loaded so are arguably best used in stereo anyway.
You are right, it has a failed HDMI board. Power amp works just fine. But I want to make a compact size two channel amp for my desktop using a compact size chassis that I have with me.
But I don’t think so I can recycle the parts of AVR to create a 2 channel stereo amp from it.
Or it is possible?
Thanks,
Simar
