I have a pair of Bob Brines FT1600 mkII speakers(using a Fostex FE167 with a BCS filter). I want to add a tweeter that sits on top of them to add more air. It was recommended that I use a hi-vi rt8-2. If someone would go over the procedure on hooking them up properly it would be much appreciated.
Thanks,
Pete
Thanks,
Pete
Pete,
Regardless of what tweeter you use, you will need at least a series capacitor. I find that around 1uF is about right, but you can get a pair each of .47uF, 1uF and 2uF and have enough range to cover your needs. You can parallel values and get 1/2uF steps from .5 to 3.5uF. Alligator clips on test leads will work fine for testing.
You may need to pad down the tweeter, so get a pair of L-pads and wire them as per instructions between the cap and the tweeter. For a final installation, you can measure the resistance of the two legs of the L-pad and use resistors of those values.
The easiest way to wire the tweeters into the speakers is to terminate the leads with a stackable banana plugor terminate the speaker cables with a stackable banana plug. Either way, installing or removing the tweeter is trivial.
Bob
Bob
