Using a CD player -AS- a DAC, via USB...
Hello all,
Something has been nagging me for a while. I'm a huge fan of the Marantz CD53/63, and from all the reports of mods, it should still be able to hold its own today with a little bit of work. And they go for peanuts on eBay!
Problem is, I never use CD's any more. All my music is stored on my PC, and pumped through a USB Audigy2 NX. It isn't a bad card, but I'm sure a semi-decent CD player would trounce it. What I'm thinking is...
Is it possible to make a simple USB i2s interface, using the PCM270x line, and patch it into the i2s path inside the CD63? It should make for a cheap external DAC for a PC, if it can be done...
Cheers!
--Rich
I'd consider putting the PC inside the Marantz case. It doesn't take much CPU power to play audio, so a Pentium "biscuit PC" or 1/2 ISA CPU card would be plenty.
But, is S/PDIF such a bad thing? Add some ASRC/receiver chip inside the Marantz, and then you can use an S/PDIF link from the PC and keep your electrically-noisy PC safely isolated from the audio system.
Aww, I thought this was a cracking idea! There must be other people who love the sound of their favourite CD player, yet cry-out for the convenience of a big hard-drive system? Wouldn't it be good to put all these poor old CD players to use again?
--Rich
The PCM270x line can output either spdif or i2s, so I can use either. I was just wondering if it was possible - should be able to make a basic USB -> i2s or spdif converter for £10 or so - and you already know how it'll sound, as it used to be a proper CD player! 🙂
spdif and i2s are different, aren't they? I'm okay with a soldering iron and whatnot, but I'm not at all clued up on the technologies used to transfer digital audio...
--Rich
