Using a 6mm knob on a 4mm shaft
For the preamp I'm building I've bought an Alps blue pot for the volume control and a Greyhill 71 series rotary switch for the input selector. the Alps is a 6mm flatted shaft and the Greyhill is a 4mm round shaft (It was supposed to be flatted according to Mouser).
I'd like to use the same knob on both controls.
Is there something I can make or buy to step the Greyhills shaft up to 6mm so I can use matching knobs?
I can't find much Googling.
Sent from my GT-I9505 using Tapatalk
Thanks Scott
I've seen a few of those on ebay. would certainly be useful if building an amp with the switches at the back and extension rods to the front. But in this case as its a really compact build I'm mounting the pots and selector in to the front panel.
jim
