Using a 2-Way System w/ Additional Woofer
Happy Holidays Folks!
Is there a simple way I could hook up a small 2-Way bookshelf system (8 ohm) to an larger auxiliary woofer (also 8 ohm) using one amplifier? I would like to be able to control the 2-way system with an L-pad to dial in just the right amount of bass.
Thank you,
John.
Administrator
Joined 2004
Unless it's a powered subwoofer, you're going to need a crossover of some kind. Could be as simple as a coil and cap.
Getting both channels into that woofer in a passive hook-up ain't going to be easy - unless it's a dual coil woofer. Or you have a "Sub Out" of your preamp.
But someone clever here may know a trick or two.
That's what I meant....the L-pad connected to the small 2-way system, then connect the outer legs (#1 and #3) in parallel to the woofer making it a 4 Ω load. Is there any reason why this WOULDN'T work? The L-pad is rated 100 watts, which I believe will be O.K. since the amp puts out 50 watts per side.
