What is the reading?
For powered operation, use the 200mV range.
For unpowered operation, use the ohms setting (the reading will be less than 1 ohm).
Resistor reading below
200mV range does not produce any readings, change to 200 and I got 25 and 24v reading
That makes no sense, so probably we should not go farther.
Readings should be either a few mV (when powered), or less than 1 ohm (when unpowered).
recently purchased an usher reference 1.5 fibale, I noticed that the right channel has an offset of 175 mv and the right channel 140 mv, since it does not have an offset adjustment trimmer, I kindly ask for advice on where to change it and if you could send me the wiring diagram, so that a friend who is an expert in the sector can handle it.
my address to send the wiring diagram crimadavide@live.it
- Usher R1.5 DC offset and Bias adjustment
