used psu for PCs
I've picked up a few old psu disposed by my friends because they switch to hight power ones. I am using a tower case (space won't be a problem) so I am wondering if I can make use of these (asuming that they are still working). I have solutions for ventialtion, turn-on switch, A/C inputs, is there anything I should be concerned about? I would properly use this (if it can be used at all) extra psu (~200w as advertised) to supplied power to the HDD and DVd drives, would that leave more power to the main psu for other equipments?
Other problems that I have in mind but need some advice :
1. Grounding
2. Interference
If these can be solved, I might save Mr. Earth by not dumping away 1 useable psu .
http://www.techspot.com/vb/all/wind...-Dual-psu-system-using-1-Power-on-button.html
http://www.gideontech.com/content/articles/196/1
Those articles show you two ways of rigging a second power supply. Yes, powering the drives from a separate power supply is safe and useful, and could provide a more stable system if your main supply is <=300W or so.
Grounding shouldn't be an issue - think about it, what's different between the way this one will work and the original? Nothing except the method used to power it up.
