Use of Dental Surgical Binocular Loupes for SMD Work
Has anyone tried these, or similar, cheap Dental Surgical Binocular Loupes, 3.5 X Dental Surgical Binocular Loupes Dentist 420mm - eBay (item 190486934809 end time Apr-04-11 17:57:45 PDT) for assembly of SMD boards. Clearly it would be preferable to use high quality dental surgical loupes, but at close to $1000 for a pair, they are out of reach. These at $65 are within budget and may be good enough for occasional use. My Optivisor works, but having to hunch over at 4 or 5 inches from the board I am working on is hardly comfortable.
Thanks for any thoughts or comments.
Terry
I get cheap magnyfying spectacles from a pound shop here in the UK for delicate work. I have a variety of magnification factors as they are so cheap.
Are these what we call 'reading glasses' over here?
That's what I generally use for magnifiers, but the working distance is quite small.
Those magnifiers that dentists and surgeons use would be just the thing.... if I had a dentist/surgeon's income!
I'm interested to read a review of those eBay loupes.
I have a few of the 'screw in eye' type of jewellers loupes, up to 10x, and some reading glasses. I have a few torches (flashlights) with Cree and other high power LEDs.
I have a close-work headset with interchangeable lenses too, but it doesn't get much use.
I'm naturally short-sighted so I can get away with most things by peering over the top of my glasses and checking afterwards with the loupe.
I make SMT circuits on homemade PCBs without really noticing, but I have been doing it for over 10 years. Everything I do is SMT, unless I'm forced to use through hole, which is kind of like it is in industry. I've done some pretty fine-pitch stuff, 24 pin TSSOP which fits 12 pins in 7.5mm. Course there's a technique for these, you just flood them with solder and then suck it off. Yes, I said suck it off.
I've taken to doing a few things in a toaster oven more recently, that's a pretty good method too, especially if you can get a laser-cut plastic stencil for the solder.
w
VictoriaGuy,
yep, they are relatively cheap (£2 £3) so I have a few mag powers depending what I'm doing. 25 years in front of computers and old age have caught up with my eyes, and shrinking electronic devices dont help.
At work, I generally use one of the arm-mounted circular fluorescent lamps with a central magnifier for both through-hole and SMD work. I'm pusing 60, but this setup usually gets the job done. When I want to look for solder whiskers or really check a SMD solder joint, I'll resort to using a binocular microscope - you want one that is wide field, relatively low power.
+1
I bought a "daylight company" illuminated magnifier a few years ago.
This is the sort of thing used in professional repair. The image is large at 7 inches and the most important thing is the focus field is clear edge to edge. This means that if you wear "reader" lenses the only impediment to a good view is whether the lens is clean on both sides.
P
I did buy them. I have not yet used them to assemble an SMD PCB, but my impression is that the focal length is just a little bit too long to work comfortably when seated at a bench. I probably should have realized that because they are designed for dentist, who usually works from a standing position. It may be that I just have to get used to them. I'm kind of used to working hunched over using an Optivisor.
