There are currently 3 options to convert USB to SPDIF/I2S which are based on:
1. TE7022
2. CM6631 or CM6631A
3. XMOS
The 1st one is considered a little old and the max speed limited to 96kbit/s. The last 2 chipsets, CM6631/A and XMOS are current chips used the current crop of convertor designs. I bought a convertor based on CM6631 and I found it to very good at the same time it is quite cheap.
I don't know the differences(technically) between the CM6631 and XMOS chipsets, my query is that, is there a clear/distinct advantage, e.g. jitter spec. of the XMOS chipset over the CM6631/A? If so please explain. If I am getting a new convertor should I buy a convertor based on XMOS or CM6631A? Thanks.
1. TE7022
3. XMOS
