JEDAC: USB DAC project with PCM2707 and PCM1794, some feedback wanted
I am about to start designing a USB DAC as my vacation project.
This will be based on PCM2707 and PCM1794, and I was thinking to make it totally USB powered. Have TI's charge pump switchers for 5V->3.3V and 5V->-5V. Do you think it is OK to power it that way?
Opamps used will be some of TI's high-end SMD chips, r2r I think and OK from around +-2.7V. But will +-5V be enough headroom?
I also want several identical line outputs (e.g. for desktop speakers, larger livingroom speakers and subwoofer), to get rid of splitter cables. Do you think they need separate buffers or would a series resistor for each be enough separation?
Check this out... I think it fits the bill...
PupDAC Overview
I was one of the prototype builders and use the DAC hooked up to two powered speakers at work. Then I do digital attenuation with Decibel on my Mac.
PupDAC Overview
That looks quite like what I will be building, with some differences. I think I will use a normal crystal. Will also only use hole-mount components. Will use single-side board.
Good to have a reference for hooking up the chips anyway.
Seems that one is running the opamps at +-2.5V, is that really enough?
What about the ferrites/inductors, there is no other value than 600-800R... are they necessary?
The reset chip for the PCM1794, according to the datasheet it has power-on reset built-in.
The analog part of PupDAC differs quite a bit from the reference design; http://www.diyforums.org/PupDAC/schematic/pupDACschematic-3.gif as compared to http://www.ti.com/lit/ds/symlink/pcm1794.pdf page 20.
What do you think about that, which is better?
OK, I see this one using the same output stage as PupDAC: PCM1794A audio DAC
This one is using pull-up resistor on the DAC reset, is there any reason to do so?
I see one might put a jumper on pin 2 (CHSL) to be able to select sharp/slow rolloff on filter.
What about this De-emphasis filter, what is that?
The Pup can drive headphones. People do it all the time. I prefer to use an amp after it. You'd have to ask the designer why he chose +-2.5v.
Most of your technical questions would be better suited to the designer because I'm a mere noob when it comes to designing this stuff. For now I just build it.
Here is a thread where you can ask questions of the designer...
pupDAC Step-by-Step Build Thread
I made something similar some years back using: PCM2707, PCM1798, OPA4228 and a TPA6120.
The TPA6120 is supplied by -12V, 12V using TI DC-DC converters.
It was a quick cheap (almost free, all ICs were TI samples) project that worked surprisingly well!
I built it back in 2005 to use with my Laptop for OS travel.
I am still using to this day (gets used every day).
The odd PC/USB-hub doesn't like it due to the large in-rush current on pluggin it in, but these days almost all are ok with it.
Front side:
Backside:
In its case with 3.5mm jack:
Front side:
Backside:
- Digital Line Level
- USB DAC project with PCM2707 and PCM1794, some feedback wanted
