US Amps USA100
I have a USA-100 amplifier that has no audio output. I have rail voltage amp powers on and was wondering if anyone knows if the relay is for the audio phase?
sorry about the grammar above, I took a measurement with negative lead on the collector and Base measured ~27. Then collector to emitter and got ~27.
I did verify that the outputs on tl074 increased with adjust gain knob.
Also I traced the signal up to the relay and if not mistaken not the relay engages it cuts off the audio feed.
Let's try this another way. Find the two speaker wires that read 0 ohms between them. Place the black meter probe on one of those wires.
Red probe on the various collectors. Do you have positive and negative rail voltage on the various collectors?
Black probe on the same point, do you have any rail voltage on the emitter resistors?
Do you read 0 ohms between 1/2 of the emitter resistors and one of the bridging speaker wires and the other 1/2 of the emitter resistors 0 ohms to the other bridging speaker wire?
If so, the relay is not in series with the speaker output wires.
I've seen them use a relay for muting. Do you have voltage across the two traces between the relay and the transformer?
Is one of the traces connected to the primary ground (0 ohms)?
I get (0 ohms) on primary ground and one trace for the relay coil.
2 pins I get 100 ohms and the 2 traces going following back to TL074acn get ~20k ohms.
I powered the amp with 100hz audio with relay removed and I now have audio
I finally figured out what the issue was. I traced back the relay coil wiring and found that one side of the coil is connected to acc or remote wire. I found high resistance from a pass-thru to the remote connection. I removed the powersupply caps and found that one caps started to leak and ate away at the eyelet. Replaced caps, ran a jumper wire on the bottom and now I have audio. This amp, the protection relay powers on and open s the contacts. When the relay is powered off it (NC) sends the audio to ground.
